I have a customised table for fetching all parts all parts from model tree . But the error in the table is it does not display alphabetically / in order of the model tree. E.G:- it goes like 001,003,002. but I need it configured as in order. Can anyone help. Attached is the file.
Thanks in advance
Hello Bhagyesh Vashi
as far as l know: Default sort "parameter" in BOM tables is weight , if nothing has been specified in SORT BY.
How to specify SORT BY parameter?
1. Create desired BOM table
2. Go to REPEAT REGION - SORT REGIONS
3. Select desired BOM table
4. Select EDIT in pop-up menu
5. Text editor will open - here you can define SORT BY conditions
- you can speicfy more parameters
- first row is primary parameter for sorting
- second row is secondary parameter for sorting
- etc.
- if all parameters are missing, than Creo use weight for sorting
For examlpe:
&asm.mbr.pozice Forward
&asm.mbr.pro_mp_mass Forward
6. SORT BY possibilities
BACKWARD or FORWARD
Search more info abou SORT TABLE or SORT BY PARAMETER:
Hope it can helps
Regards
Is there any way you know of to do this at the format level?
When we start a new drawing, we would like the BOM to populate in order by part number.
It currently orders it by the "description"
It is a huge pain to need to organize it each time a drawing is made.
In your drawing template, set the sort order in the repeat region so it formats the way you want.
After I posted this I realized I was just not pressing enough buttons.
THank you!
Mark correct answer if you question has been answered ... else add another question
this is not my thread, so I cannot.
Thank you very much @mbonka for this answer.
We would like to sort the Table by Descending mass, so &asm.mbr.pro_mp_mass Backward.
But for it to work we need to display the property in the table, what we would like to avoid.
Do you know any trick to sort the table by a parameter which is not shown?
BR
CHENAMA
my tip...
1.]
Start with simple repeat region ... 1 column containin asm.mbr.name
Is component order equal to model tree ? I hope so.
Check repeat region attributes setting.
2.]
Go back to your table.
Check repeat region attributes setting. Try to set it as in 1.]
MH
