Hey,
i am working with creo parametric M020 and i am trying to edit the BOM Balloons, but somehow i can't change them to take a custom bom.sym.
I tried the following command:
any ideas?
greetz sam
hi Samuel,
You can try following.
Select your table with repeat region using "Select Table" then click on Properties either from RMB menu or Table tab. After that click on BOM Baloons tab in the table that has opened and set your custom BOM symbol under Type.
hi Samuel,
