Customized hol. files changing on reopen?
dfrost
7-Bedrock
Has anyone run into this? Or know a work around? I have created my own hol. files to be used on drawings and am very happy how they work.
These hol. files are stored on my harddrive in the text folder with the defaults. My problem is this: if someone else opens my part files, the holes change from unc or unf to iso. I believe it changes specifically to iso because it is alphabetically at the top of the list of default hol. files. Also, if I open a file I created before my custom hol. files, they also will default to iso. I've heard talk of using a family table with hol. files, would this be a better way of using custom files? I doubt everyone is going to want to switch to my hole files, plus what would then happen to old drawings?
Any help would be awesome! I really don't want to have to go back to the default hole files and then go thru each file and change it back to default.
Thanks you
0 REPLIES 0
