Customizing Table w/ Repeat Region
EricHuffman
2-Guest
Gurus,
How can I add multiple models to an existing repeat region or table??
I've got an assembly drawing with a fully populated BOM table with repeat region. Now I want to add the related tooling parts to that table but I don't want to assemble the tools in the assembly model because I don't want to deal with simplified reps, family tables, or extra layers.
What I'm hoping is just to add a row to the table and somehow copy/paste the part parameter info (&detail, &weight, etc) into the row but all my attempts have failed.
My workaround is I set the desired model, then add a row, then manually enter text into each cell (&detail, &weight, etc). This is a bit tedious. Can you think of any way to automate this process?
CREO 2.0 m110
Windchill 10.0 m030
Eric
4 REPLIES 4
TomU
(To:EricHuffman)
Have you considered using "Include"? This will make them part of the assembly for BOM purposes but not actually load their geometry.
[cid:image003.jpg@01CFD2A5.7DD54780]
Tom U.
PERFECT!!! Thank You Tom! That is better then what I was hoping for.
Eric
This is awesome! Will "included" parts come along for the ride when you do
a backup? Also, do these parts load into ram when assembly is opened?
TomU
(To:EricHuffman)
Yes, and Yes.
