DEF_DENSITY no longer works in Creo 8
Mat
Hi there,
My company updated to Creo 8.0.1.0 some weeks ago. Now it turns out, that the model check test "DEF_DENSITY" does not work anymore in Creo 8.
In Creo 8 every part gets the default material "PTC_SYSTEM_MTRL_PROPS", which has the density of 1.0.
The test DEF_DENSITY should check, if the density is 1.0, but the test passes.
Since we use modelcheck as a gatekeeper for our windchill, there is a pretty chance, that the pdm-system gets filled up with neutron-star-like parts.
Does someone knows a workaround?
Mat
(To:Mat)
ok, I think I found a workaround.
In "checks.mch" I added this line:
PRT_DENSITY          YNEW       E       E       E       E       E
In "constant.mcn" I added the some boundaries for the density:
DENSITY_LOW 0.000001
DENSITY_UPP 0.9
Looks promising for now.
9 REPLIES 9
VladimirN
(To:Mat)
Mat
(To:Mat)
DENSITY_UPP 0.9
VladimirN
(To:Mat)
I'm glad you solved your problem.
KenFarley
(To:Mat)
I guess the tricky part would be if someone has a model that is metric...I wonder if modelcheck will take that into account when applying your criteria? We don't use ModelCheck, so I'm just curious.
Mat
(To:KenFarley)
works absolutely fine with metric parts. We use kg/mm^3 as a density unit.
I guess, if You use e.g. tons/feet^3, You have to adjust the low/upp-values.
llie
(To:Mat)
This is working for us as well in Creo 7.0.4.0. Is there a ModelCheck setting to flag PTC_SYSTEM_MTRL_PROPS material?
Mat
(To:llie)
Yes, You can change settings for PTC_SYSTEM_MTRL_PROPS.
https://www.ptc.com/en/support/article/CS326615
But I recommend to keep the default values. Thereby You are forced to assign a correct and real material to the part.
Mat
(To:Mat)
Update:
one of my engineers had problems passing this modelcheck test.
It turned out, that his part was made of a foamed material. So the lower boundary of the density was still to high.
Had to alter the limits to
DENSITY_LOW 0.0000000001
DENSITY_UPP 0.9
DP_10479309
(To:Mat)
Hi Mat,
I was looking around for a ModelCHECK setting that flags this as well and just stumbled upon this article today: Article - CS378862 - ModelCHECK check DEF_DENSITY is unable to report error/warning in legacy parts with assigned density as 1.0000 (default) and no material. (ptc.com)
I figured I'd post here as well in case other people are searching around for the same thing.
