While exporting an drw into an dwg file...if i open that file in 2d softwares after export,the scale was not as same as it was in CREO DRW !
what should i need to do while exporting to get the exact scale value in both ?
Iam using 9.0.3.0 version of CREO !
please clarify me on this ASAP!
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
Not sure, but perhaps you can try modifying your system configuration:
please provide:
Also attach picture of Creo window with marked problematic items.
Also attach picture of 2D software window with marked problematic items.
