Darwing Format question
vloos
Our drawing formats have a table for revisions created in the .frm .
The first row of the table has a cell text height of .12" and the
justifications are center middle with the exception of the "Description
of Change" which is left middle.
When I insert another row all cell heights default to a height of
.156250" with left justification (that's not even the default note
height in Pro).
Each cell has to be edited to the correct heights and justification.
Why does it not default to the existing upper row cell height? Can this
be corrected in the .frm?
Vinson A. Loos
Mechanical Engineering
DRS Tactical Systems - Melbourne, FL
(321) 727-3672 Ext. 3409
- <">mailto:->
www.drs.com <">http://www.drs.com>
NOTICE: This e-mail transmission (and/or the attachments accompanying it) may contain confidential or proprietary information belonging to DRS Technologies or the sender. The information is only for the use of the intended recipient. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or the taking of any action in reliance on the contents of this information is strictly prohibited. Any unauthorized interception of this transmission is illegal under the law. If you have received this transmission in error, please promptly notify the sender by reply e-mail, and then destroy all copies of the transmission.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior written approval from the U.S. Department of State."
BillChapman
(To:vloos)
Tables default to the settings in your drawing options file. Change the text height in the drawing options file to the value you want, then create the table and it will default to the value you need. If ptc has put a way to handle this more gracefully I would like to know.
Bill
vloos
(To:vloos)
Bill,
If you mean the .dtl file, ours has a drawing_text_height = 0.18750 .
There must be something else driving the 0.15625 height.
Vinson A. Loos
www.drs.com
My understanding of tables is that they adopt the default settings when
they are created and then that is the default for that table. They do not
follow the drawing defaults and they cannot be changed afterwards. So if
you want a table with different (specific) defaults then you have to
change the drawing defaults before you create the table. And I'm not sure
if justification is even included in the defaults for tables.
Doug Barton
Senior Mechanical Designer
Parker Hannifin Canada
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x309
fax 204 452 7156
www.parker.com/ecd
