My problem:
When I create the Datum Tag using Datum Target Annotation Feature and remove it, the Datum Tag name previously used is still unable to change and to re-use.
If I pick a wrong plane or surface I cannot rename the Datum Tag.
Is there a way to fix this issue?
Thank you,
Arek
Can you create a new part and share without removing anything with some steps to recreate the scenario?
