I just do not know how to make the datum B and datum target A1 as shown in the drawing. I've tried several button but can not figure it out. Please help, thanks.
For datum B I don't think you can attach the datum symbol to the leader as you're showing unless you're creating manually or unless there is something new I'm not aware of. It will attach to the leader across from the dimension, the feature control frame, or to the geometry. For the datum target you need to create the target area and center axis in the model and change the axis to a set datum. In the drawing show the datum and diameter dimension for the target area and the create the draft datum target. You can also create it in the model and show it on the drawing.
