Maybe this helps - PTC also call them "Shown Datums"
x
Tony,
Are you looking to set the Geometric Tolerance "tag" of an axis to a layer or the whole axis?
FYI - This is probably the type of question that should be done as a Tech Support Ticket on www.sigmaxim.net rather than here in the Creo Automation threads.
Joel Beckley
