I can't seem to position the datum symbol right beneath the dimension. Somehow, is placing the symbol in the middle of the leader line.
I tried config settings (gtol_datums to std_ansi OR std_asme_y14.5_2018) , annotation dimensions without much success. Any other tips?
thanks
It seems that your question is for Creo Parametric. Here you are in Creo Elements Direct Modeling.
You should move your question to Creo Parametrics to have a better chance to get an answer.
Do you mean to place the DFS like so:
