Hi folks,
After setting of tolerances , If I click OK. It will not displaying Tolerances on dimensioning.
For that i need to do manually everytime by using @++0.5@#@--0.25@#. Its very difficult to do for more dimensions. Its time taking process.
Can anyone help on this to fix directly on dimension without any manual inputs.
AraviK
Check out this discussion, I think that will answer your questions:
http://communities.ptc.com/message/191103#191103
Thanks, Dale
If that solved you issue, you may want to mark it so that those who find this discussion later will know that you found your solution.
You may find some tips to follow in https://www.youtube.com/watch?v=B2O9pb-Y_ys
hope its useful.
