We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
Default modelisation planes
gduval
*My english is not really good. I'm gonna do my best so that you can understand my issue.
I just installed Creo 2.0 (student edition). When I model a part, I dont see any reference plane in the modelisation window. I see the ''RIght'', ''Top'' and ''Front'' plane in the model tree, but these are not visible in the mod window. I think if you look at the screen shots in attachment you should understand my issue.
Mahesh_Sharma
22-Sapphire I
(To:gduval)
Which graphics card do you have on machine?
----- Rename config.sup (if any) in <Creo 2.0 Install location>\Common Files\M110\text > launch Creo and check the datums.
If still fails, move to below steps.
Next step:
Remove the one in list.
1. Right Click on Creo 2.0 shortcut icon > Properties
2. Click in Target path and move cursor to extreme right (at the end of .....exe")
3. Add a space after .exe"
4. Type -g:win32_gdi > Apply > Ok
8 REPLIES 8
AndyHermanson
(To:gduval)
You need to turn on your datum display. Probably in the top center of the window in a fresh install.
Thanks for trying to help, but as you can see, I still don't see the planes even though theses display buttons are turned on. What+I+see.PNG
Mahesh_Sharma
22-Sapphire I
(To:gduval)
Guillaume,
This seems to be due to graphics.
Add config option graphics win32_gdi in config.pro and relaunch.
You can directly add that in config.pro available in <Creo 2.0 install>\Common files\<datecode>\text\
Hi Mahesh,
I think I dont understand how to fix this. I just don't find that win32_gdi. Can I set this from the Options/Configuration/ and then what do I do ?
Mahesh_Sharma
22-Sapphire I
(To:gduval)
Ok
1. Browse to <Creo 2.0 Install location>\Common Files\M110\text (Default is C:\Program Files\PTC\Creo 2.0\Common Files\M110\text)
2. Open config.pro in notepad
3. Add graphics win32_gdi > Save and close.
Thanks for your explain,
I did it, as you can see on the screenshot below, but it still does not fix my problem and I dont know why. Config.PNG
Mahesh_Sharma
22-Sapphire I
(To:gduval)
Next step:
It works now!! Thank you so much Mahesh for this step-by-step answer.
I really apreciate
