I need to remove a row from a table I have already created. I am able to delete contents but where is the delete row?
I also have a flag note in between to defined dimensions but need to either add a leader or be able to have arrows on each side of the flag note. I tried creating a dimension so I will have the arrows and then deleting the dimension text but the text comes back. What are my options?
See images below.
1.] row deletion
2.] flag note
MH
1.] row deletion
2.] flag note
MH
Where do I find Selection Filter? What table is that under. I do not see it under the table tab.
The cheating for the flag note worked great. I like it.
Selection Filter combo box is located at the bottom right corner of Creo windows.
MH
Perfect. Thank you VERY much for the prompt help.
Don't forget to mark Martin's answer as correct for those who may search on the topic later.
Hello MartinHanak,
Your detailed explaination helped me alot,Thanks..It's working exactly what I intended to be..Thanks
