Delete or not show solid lines across a part
Raaid
Hi Everyone,
I'm new to Creo so here goes. I have an assembly of a pipe and an end cap. Whenever I import my assembly into drawing mode it shows the end cap with multiple solid lines across the part not only on the outer edges. How do I cancel these lines and only show the outer edges of the part and the hidden lines?
1 REPLY 1
StephenW
(To:Raaid)
I'm guessing your drawing view is showing tangent lines.
Right click on the view, go to properties, view display, set tangent edges to None.
