All the bells and whistles and I keep getting memory errors and subsequent smooth transitions to the OS.
This is whatit shows under 'My Computer'
Dell Precision T5400
XP Professional 32-bit
Intell XEON
E5410 2.33 GHz, 2.33 GHz
3.0 Gb RAM
Nvidia Quadro FX 1700
Running WF 3, Intralink 3.4
Load a couple of assemblies, maybe using 2.0 GB of RAM and get a Memory Running Low message in ProE- if I don't do something quickly to free up space, KA-POW and I witness a quick, but elegant, departure of ProE
Does anyone have any suggestions of have you had similar problems with this chipset/configuration?
Paul
Windows actually limits the amount of memory per process to 2 GB (usually more like 1.7). You can set it to allocate up to 3GB which might resolve your issue (you must be opening fairly large or complex assemblies?). There is a PTC doc on it here:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=111330
Or go to Microsofts site directly:
http://support.microsoft.com/kb/833721and scroll down to the /3GB option
Hope this helps.
Colleen
