I need to provide mass of a servo motor to a rotating arm, since servo motor model is provided by the vendor and has the spec of weight 200gms. i have assembled into my main assembly. i need to set mass to it for my further analysis. since servo has may parts in it it will be a time consuming - is there a way we assign weight to that assembly and proe will consider for analysis and BOM generation?
