Design steel frame buildings with any PTC products???
ptc-6774025
I have seen a friend use Creo to design wheelchairs, perform FEA and minimise the materials used as a result. I am a steef frame building constructor which are subject to design standards for wind force, muti axial loading, weight bearing etc. I wondered if there was a PTC application for such? If there was I could reduce materials, apply reinforcing with different points of application, etc.
Anyone have any ideas? I would like to frame a discussion on this.
2 REPLIES 2
(To:ptc-6774025)
Unfortunately this subforum has the misleading name "Community Help". It is meant for discussion about the forum and the forum software itself.
For questions about Creo please post in the approprioate section here
http://communities.ptc.com/community/post!input.jspa?containerType=14&container=2023
or in a suitable subspace.
Thanks for pointing this new member in the right direction Werner, as you suggested I've moved this discussion into our community.
