Hello Folks,
I am using Creo 7.0 and partial or detail view generates as full view in pdf file when working online (windchill connected). But when I generate pdf file offline (with standalone creo / offline) same view remains as is as they are in creo drawing.
I wonder if anybody faced this issue. Any help is appreciated!!
Mani
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Hi @mrajan,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
