Diameter Dimension - Single arrow leader
mstirnemann
Is there a Drawing Option setting that would allow the default diameter leader to be the single outside point (like on the left) instead of the double inside (like on the right).
Currently, we have to double click and then middle click to create the .625 dimension, then you have to deselect, left click to re highlight and right click to flip the arrows.  90% of our diameter dimensions end up with the single arrow, so we would like this to be the default config option.
Thanks PTC Community!
6 REPLIES 6
I am not sure about the config option but with the following method you can reduce the number of clicks
1. Select all the dimensions using the  smart window selection for dimensions ( it will select only the dimensions covered by the window)
2. Right click on the screen and select "Flip Arrows"
3. All diameter dimension will be as per your requirement
ddhondt
(To:Praveen)
Is there a config setting so it comes out standard that way?
Thanks Praveen, but we know about the smart window and also the ctrl technique.  I'd rather skip those steps.
D'Hondt, it seems as if I'm not the only one asking for this to be standard.
StephenW
(To:mstirnemann)
Just last month an idea was created for exactly this.
Add ability to set default diameter dimensioning
Alright so you (Stephen) are saying there's no hope for a quick solution... Great.
It's odd that the location of the text relative to the leader line is a config option, but the arrow location is not...
StephenW
(To:mstirnemann)
To the best of my knowledge, all hope is lost and now we are relying on a product enhancement suggestion that has a less than zero percent chance of being implemented.
Too bleak??? Well I voted on it so I guess maybe I still have a little hope but..........
