Did something happen to Undo command in M070?
rbobroski
It works on some features but on others it doesn't do anything now. Like for example I could have a datum plane offset at .500. Change it to .875, hit undo, it goes back to .500. On the following feature I have a diameter extrusion of 2"; change to 1" and undo, nothing happens. Delete circle and undo, nothing happens.
2 REPLIES 2
Hello Ryan,
I just tested the behavior in Creo Parametric 3.0 M070 and just used your examples.  I was able to undo the action of changing the diameter dimension from 2 to 1 and also undo the action of deleting the extrude.
Would you be able to attach the model and any configs you are using?  Also, is this the behavior you see on all machines or just on a specific machine?
Amit
After a second reboot it stopped happening now. Maybe it was just backlogged a bit. I will close this and if it happens again re-inquire.
