Set drawing detail option update_drawing 2890251 and update the sheet.
Please try with Creo Parametric. 7.0.6.0. Try also with a new model and drawing.
Is it on your specific drawing only? If so, we can open a TS case.
I tried to reproduce, but it works fine:
Thanks for your reply, apparently is a specific drawing issue, since I'm trying to replicate the same issue with another model and drawing (new) and I cannot do it, both dimensions. driven or the 3D annotated are good and showing, even if I hide the layers.
But, in the old drawing I have (it was created using earlier versions of CREO), the dimension on the drawing tree appears as "suppressed" and if I select it, it is highlighted successfully, and if I go directly to the layer status of that particular view, the suppress status is gone and the dimension is showing, but if I use Draft Update, the suppress status does not appear again but the dimension is gone.
Data specific, so opening a technical support case. (C16164116)
Thanks for the support, this options really does the trick!
I am Using creo Same issue facing for Datums, Is there any other solutions for It
Thank You!!
