We are trying to figure out how a user was able to create a draft dimension and rename it to match a driven dimension.
Does your drawing already have an existing CREATED dim called DIM8?
You can rename created dimensions. They simply renamed it so it matched the driving dimension.
I tried that but it won't allow it.
Nice catch. User had already renamed a dim but did not change it to @S. Thought the user had some new trick I had not heard of. Thanks for your help!
