We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
Direct Diameter representaion on the drawing
AraviK1
Hi folks,
How to place Diameter dimension directly on the drawing instead of Radius without edting.
At present i am doing like using this "@O"
Can anyone help me?
AraviK
AraviK1
(To:AraviK1)
Got the solution. Thanks HatimAbdul.
HatimAbdulSilver
123 posts since
May 16, 2008
You can eith delete it and recreate it or you can select the dimension, right-click. From the popup menu select (edit attachment). Click twice on the arc/circle and middle click to obtain the diameter dimension (rad dimension is by one click on the arc/circle).
AraviK
1 REPLY 1
AraviK1
(To:AraviK1)
HatimAbdulSilver
123 posts since
May 16, 2008
AraviK
