Nvidia Quadro K2000M graphics problem
scooke
Hi ProSys guru's
Hoping someone has already solved this problem and can help.
We have a new machine, a HP Elitebook 8570W i7-3740QM CPU @ 2.70 GHz with 8
GB RAM and with Nvidia Quadro K2000M updated to the latest driver
9.18.13.1143
OS is Windows 7 64 bit SP1.
We are working in WF2 but are in the process of migrating to Creo2.
In WF2 the real problem is in drafting mode when double clicking in a table
cell to enter data, ProE crashes. It also crashes if one tries to amend the
text of a dimension, or to edit a note outside of a table. All modelling,
assembly, EMX, and tool design modules seem to work fine.
Other symptoms are when WF2 starts the display flashes once for an instant
as the program splash shows and then the program opens normally. Also
dragging a dialogue box (eg create point) over the main graphics area
leaves a "trail" of the box behind it which then refreshes as you let go of
the mouse.
None of these problems are seen in Creo 2.
Anyone else seen this?
Thanks in advance
Steve
This email is free from viruses and malware because avast! Antivirus protection is active.
bgruman
(To:scooke)
Steve,
I do not have a specific suggestion for your WF2 Drafting issues (Its been
years since I was on WF2), but maybe your problems are all related because
of the old software with a newer OS.
I seem to remember back in the WF4 days that there was an option for "Show
Window Contents While Dragging" that needs to be turned off. You can
find this in -Control Panel - System - Advanced System Setting -
Performance - Settings.
Find the option and uncheck the box.
While your there, you may want to just turn off all the "Eyecandy" and see
what happens. Hit the button for "Adjust for best performance"
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
gbon
(To:scooke)
I can’t remember exactly but I had a similar problem in WF2.
The problem was coming from font directory.
When you double-click in a cell, ProE load fonts list and that cause the
crash.
This was solved when setting proE font directory in different location that
Windows\fonts.
Hope this help,
GB
De : Bernie Gruman [
find this in -Control Panel - System - Advanced System Setting - Performance
- Settings.
what happens. Hit the button for "A...
">http://www.GrumanCreations.com> www.GrumanCreations.com
On Tue, Dec 10, 2013 at 1:54 AM, Steve Cooke <
<">mailto:-> -> wrote:
Hi ProSys guru’s
9.18.13.1143
leaves a “trail” of the box behind it which then refreshes as you let go of
the mouse.
Thanks in advance
Steve
_____
Site Links:
<">http://portal.ptcuser.org/p/fo/st/post=121802&anc=p121802#p121802> View
post online <">http://portal.ptcuser.org/p/fo/si/topic=12> View mailing
list online <">mailtoSmiley Tongue-> Start new thread via email
<">mailtoSmiley Tongue-?Subject=Unsubscribe>
Unsubscribe from this mailing list
iwis
(To:scooke)
Interesting - I can't even install WF 2 on Win 7.So i was told that it is not possible. Volkmar Nyga GesendetSmiley Very Happyienstag, 10. Dezember 2013 um 16:07 Uhr
Von:"Bernie Gruman" <->
An:"Steve Cooke" <->
Cc:"-" <->
Betreff:[proesys] - RE: Nvidia Quadro K2000M graphics problemSteve,
I do not have a specific suggestion for your WF2 Drafting issues (Its been years since I was on WF2), but maybe your problems are all related because of the old software with a newer OS.
I seem to remember back in the WF4 days that there was an option for "Show Window Contents While Dragging" that needs to be turned off. You can find this in -Control Panel - System - Advanced System Setting - Performance - Settings.Find the option and uncheck the box.
While your there, you may want to just turn off all the "Eyecandy" and see what happens. Hit the button for "Adjust for best performance"
Good LuckBernie
Bernie GrumanOwner / Designer / Builderwww.GrumanCreations.com
scooke
(To:scooke)
Hi Bernie,
Thanks for the help; we knew the option existed and spent a long time
looking for it with no success. You instructions took us straight there.
Unfortunately it didn't prevent the crashing but has removed the trail of
the box which is good.
Best regards
Steve
