I am using Creo 7.0. I have an assembly. I want to show the BOM position of a particular part in the drawing as a note. Can we extract that BOM position as a parameter in the drawing. So that whenever the position of that part change, it will be refreshed in the drawing too.
Thanks for the response
No, unfortunately it is not possible to use repeat region parameters outside of the table or balloons
Thanks for your response
