In solidworks there is a Display/Delete Relations PropertyManager that will show all constraint for a selected line or point. Is there something similar in creo?
Thanks!
Hi, you can use "Tools/Relations" to check for relations set in different levels, see below:
Thanks BHOoi,
Do you know if there is a way to see all the constraints pertaining to a certain line in a sketch using that tool?
Thanks!
I'm not sure why when I select relations it not showing any dimensions or sketch relations.
Ok, Yea I was hoping that there was a summary of the constraints controlling the line or point then have a way to delete all constraints so the line or point could move freely.
Thank you for the response!
