Drafting help needed..
RocketIII
Long time lurker, first time poster...
I have a drawing view consisting of a 60-hole bolt circle. I did a Show Model Annotation to display the centerline of the bolt circle, which includes the center line tick marks for each hole. I then edited the the bolt circle pattern to add an an additional 4-holes. The problem I'm having is I'm unable to get the center line tick marks for the new holes to show in the drawing view. I've regenerated the model, updated the views...I tried to show the axis for the new hole directly via the model tree, all to no avail. I can get them to show if I create a new view and show model annotations.
Please help.
Thanks!
4 REPLIES 4
Dale_Rosema
(To:RocketIII)
In the drawing, while your in annotation, right click on the pattern and go to show annotation.
Deselect all the dimensions (so they don't get added right now).
Go to the last (looks like a datum target).
Deselect all the centerlines.
Hover over the centerlines until you find the 4 that are missing.
Select them and the click OK
(WF5/Creo)
Hope this helps. Dale
That's the problem...there's nothing to hover over...they (the missing axes) aren't showing up.
The hole center line will display correctly if I create a new view after the hole pattern has been created. If I could get the axes to display in the old view I certainly could select them there to add them. Could this be some kind of layer issue? The axes do show up in the model, just not in the drawing view.
Dale_Rosema
(To:RocketIII)
See if these pictures help. The first picture shows the part without centerlines.
The second picture show where I have selected the part from the menu and right-clicked on show annotation while in the annotation tab.
After having deselected them all (they switch from yellow to red in my case), I am hovering over A-52, though you can see the mouse from the screen shot. It is turning the axis to a Cyan color. If I select that, it turns back yellow. Click OK and nows it is in the drawing.
Thanks, Dale
