Good day folks,
This is Edward,
I’m working on the generation of drawings with CREO Parametric with repetitive steps. I want to automate the generation of the same and found that by using a function called "Drawing Program" I can do it. However, I am new to this topic. I would like to know where I could start, some book, video, example, etc. , which can serve as a reference for me to be able to make sketches.
Thanks in advance.
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
Good morning,
Thank you very much for the observation and guidance.
I will move my post.
Have a nice day 🙂
