Hello, I have created a drawing template with bom tables pre-set so when I create the drawing, everything is already in place. The issue is, I want it to read a specific simp rep on creation. And right now it seems that "Master" is the only option?
I have already searched for threads about this and found one...
"Creating Assy Dwgs - Is there a way to pre-set the Simplified Rep?"
However, the post is from 2014 and the links to a solution seem broken.
I'm hoping that since that was posted 11 years ago, surely they have come up with a proper way to address this?
Any help is much appreciated. Thank you!
You are right that doesnt happen when selecting from default template. Sadly, I dont see any config option so I guess its creo bug.
When creating drawing after choosing format there is popup window to choose which representation you want to create drawing from.
Thanks for your reply, however that popup your showing happens after you select a "format".
Now create a drawing and select "template", if you get the same result then I'd like to know how.
