Hey Guys I am here trying to make a template for ANSI standard based off some dxf files generated originaly in autocad. I make a format with the tables and such edit them to my liking then create a drawing to save as a .drw and my template, but the issue is whenI go to verify my work opening a part with the template drw the codes for part numbers, etc do not update and the text boxes are uneditable/clickable. I know the template parameters are applied however because of the default view state the model comes in as. Any help would be appreciated.
Demetri Karanikos
