Drawing: Witness line
kmark
How do I darken the witness lines in a drawing to be printed darker? Creo 1.0
(Witness lines no longer visible when the drawing is scanned for final release with signatures)
i hv this pen table discription file which i think might help u
pen1_line_weight 3 - outline geometry, section text/arrows
pen2_line_weight 2 - dimension lines and leaders, text, witness lines
pen3_line_weight 1 - hidden lines
pen4_line_weight 2 - drawing frame
pen5_line_weight 3 - sheet metal
pen6_line_weight 3 - sketch lines
pen7_line_weight 1 - tangent edges
pen8_line_weight 4 - text
pen table can change from the config.pro
tool>option>find
5 REPLIES 5
TomD.inPDX
(To:kmark)
Pen Tables.
A search of the forum will yield some great information.
tool>option>find
Thank you for your help Dalbeer singh. Adjusting the pen2_line_weight seem to fix the problem both with direct printing via proe and with pdf export and then printing exported pdf.
BrianMartin
(To:kmark)
Hi Kevin...
Did you resolve this yet? Antonius is correct... the answer is pen tables and a pen table file. If you look at this link to another answer I gave, you should have all the information you need.
http://communities.ptc.com/message/173301#173301
Please let us know if you got this working correctly. My answer is about 3/4 of the way down that link... I attached 3 files including a reference document on pen tables, a pen table file (as an example), and some other helpful stuff.
Thanks!
-Brian
Thanks Brian, Thank you for your help and follow up. It turns out that the actual issue that I was having is printing those files I created via File/Save as/Export/ pdf within Creo 1.0. But your trick pen2_line_weight seem to work well with both direct printing via proe and with pdf then printing pdf. Thank you so much. Regards,
