Drawings: Quantity Balloon Changes - Info Window.
Airfix
Creo 7.  I had to switch out a part in an assembly and I updated the drawing that has repeat regions with find number balloons.  My drawing shows all the correct balloons and quantities but every time I open it up I get an info window that says:
Total quantity for XYZ.PRT in ABC.ASM has been changed to Zero.  Associated balloons have been removed.
See the attached file.
I get the context of what this is saying but I don't know why I get it every time I open the drawing.  I've looked through all the drawing views to make sure I don't have a hidden balloon annotations.  Does anybody know what I need to do to prevent this info window showing up every time?
Airfix
 Draw
Just saving the drawing doesn't fix this message.
I had to re-assemble the XYZ.prt and then save.  Then I deleted the XYZ.prt and everything was back to normal with no message.
I'm unable to upload my data as there is a lot of proprietary information on the drawing.
It seems like I found a work around though.
Cheers,
Airfx
kdirth
(To:Airfix)
This should go away after you save the drawing once.
Airfix
(To:kdirth)
The drawing has been saved at least once since then probably more than that.
I'll try that again though.
MartinHanak
(To:Airfix)
Airfix
 Draw
1.) resume xyz.prt and and investigate what happened
2.) upload your data for testing purposes
Martin Hanák
Cheers,
Airfx
