Dxf's
ptc-2266347
Dxf's
Hi im getting a problem when i save a drawing as a dxf to send to a manufacturer the sizes on my Pro-e drawing are fine but the dxf is showing the scaled sizes i.e im using scale of 1:2 on my Pro-e drawing which is still showing the correct dim(100mm) but when this is opened as a dxf by the manufacturer its showing(50mm) any ideas?
When exporting to a dxf from a drawing it is always necessary to set your scale to 1:1. In the pro/e drawing, proe knows that the model view is scaled and the dimensions are correct because of that, but, when the geometry is exported, it comes out the actual size shown in the proe drawing.
thankyou but could you explain(set youre drawing to 1:1)or more precisely how to set youre scale(very new at this) thanks
Mr. Buchanan, I understand. In the drawing file. The scale value is shown in the lower left corner of the screen. To change it, simply double click on it with your left mouse button and type in the number 1. Thanks, Clifton
hi thanks again but i have already tried this but the results are the same
as far as i know, the value of dimension cant be changed while u save a drw to dxf. A dimn which is 100 in drw, will be 100 in dxf also. but yes, u can change the actual length. If ur proe drw scale is 0.5, then actual length of 100 size will be 50. If u want this actual length to be 50 (or 100) in dxf, then u can do it using config option - dxf_out_scale_views. If u set it YES, actual length in dxf will be 100 (means ur dxf will be 1:1). If u set it NO (which is default), actual length in dxf will be 50. But in both cases, the dimn will show 100 (the same as in proe drw file). Ankur.
