I'm trying to output some parts in ECAD for the electrical guys to
import, but I can't figure out how to get Pro to output a connector
outline. The help says I need a section plane, but, as usual, doesn't
tell me how to create one. How do I create a section plane for a
component outline, and how do I do that in an assembly (as in a
connector model that happens to be an assembly)?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
