ECAD section plane
kwsauter
ECAD section plane
I'm trying to output some parts in ECAD for the electrical guys to
import, but I can't figure out how to get Pro to output a connector
outline. The help says I need a section plane, but, as usual, doesn't
tell me how to create one. How do I create a section plane for a
component outline, and how do I do that in an assembly (as in a
connector model that happens to be an assembly)?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
3 REPLIES 3
ECAD section planeHi Ken,
For a part to be exported via IDF it needs to have a uniform cross section. You basically need to create a protrusion from the base of the part to the top of the part that uses all of the outside geometry when looking at the part from a top view.
Attached is an IDF emn file that was generated from the attached .prt file.
Also, visit www.simplifiedsolutionsinc.com for more Pro/ECAD information.
If you have any questions do not hesitate to contact me.
Keith
Keith Richman
Simplified Solutions Inc.
410-420-7853 (United States)
If anybody is interested in those two files that were too big to go through
the exploder, send me an email and I will pass them along.
Keith
Keith Richman
lwh
(To:kwsauter)
To give mechanical sketches to electrical layout, You need to create an ECAD area of type 'Place Region'. This will transfer its planar geometry to the electrical system.
They have to read and interpret it properly, though...
