Easiest Method to Start Pro/E w & w/o Intralink
RichSerafin
Hi Folks,
I need to have 2 start up methods for Pro/E. Our original batch file starts Pro/E with Intralink. What we need is a way to launch Pro/E without Intralink since we're going to SAP for our PLM solution. I was able to copy & modify .bat & .psf files so Pro/E will launch without IL but now the original batch file runs and starts up in my prowork folder instead of the IL WS that I select after IL login. I can navigate to the desired WS and set it but users are not going to like that work around. Any thoughts? TIA.
Rich
1 REPLY 1
The answer was to rerun Pro/E setup and define a new license configuration minus the IL hooks. The SAP application now points to the second license configuration.
Thanks to those who responded.
