Does anyone have any suggestions for improving Pro NC?
I would like...
1 Search tool in Play Path (CL player)
2 Dialog Play Path allways top (no hidden)
3 Surface milling step devide on 4 separete step a)Straight Cut b) From Surface Isolines c) Cut line d) Projected Cuts
When using the process manager i would like to be abel to change values within the cells instead of having to "edit" the sequence. That would be the best ![]()
How about the ability to continue working while a tool path is processing.
So I was reading some of the Forums on the PTCuser.org (http://portal.ptcuser.org/p/fo/st/thread=45470) site looks like there is going to be some big changes to the next version of Creo as it pertains to the NC side of things. I for one am looking forward to some updates.
