Does anyone have any suggestions for improving Pro NC?
I would like...
1 Search tool in Play Path (CL player)
2 Dialog Play Path allways top (no hidden)
3 Surface milling step devide on 4 separete step a)Straight Cut b) From Surface Isolines c) Cut line d) Projected Cuts
When using the process manager i would like to be abel to change values within the cells instead of having to "edit" the sequence. That would be the best
How about the ability to continue working while a tool path is processing.
So I was reading some of the Forums on the PTCuser.org (http://portal.ptcuser.org/p/fo/st/thread=45470) site looks like there is going to be some big changes to the next version of Creo as it pertains to the NC side of things. I for one am looking forward to some updates.
