Erasing Datum planes
bmacdonald
Erasing Datum planes on drawings using Creio. You use to be able to select  all Datum's at once and erase. Seems this has gone away. Anyone one know how to still do it.
3 REPLIES 3
Open a drawing >> select filter Datum Plane
>> Select planes into "rectangle" >> RMB > Erase
Vladimir
Best Regards,
Vladimir Palffy
Hi Bill,
I am assuming you are talking about erasing Set Datum Planes and not just regular datum planes.
The steps that Vladimir Palffy‌ mentioned above will work.  But one thing to note, is that the Annotate tab, in the drawing, must be active, in order to see Datum Plane as an option in the Selection Filter.
Amit
Thanks Amit for your comment
Best Regards,
Vladimir Palffy
