Excel Analysis to import Parameters
ptc-5280311
I am using an excel analysis to update parameters in CREO. I use a relation to set the model parameters equal to the parameters that are created from the excel analysis. The issue that I am having is that I cannot get the analysis parameters to update when I modify the parameters in the excel spreadsheet. I was able to get it to work for a while but once I closed out of the spreadsheet and CREO and tried to reopen it to use it again the link seemed to be broken. Is there a way to setup this link so that it doesn't get broken when the program is closed.
Thanks.
0 REPLIES 0
