I have a drawing of a sheet metal part that has two instances that differ by one dimension. These instances create two flat patterns. I want to display the instances in a table in the drawing. I want to display the part in flat pattern state, and I want the table to only contain flat instances. In other words, I need to filter (exclude) bent instances (they are identical except that one flat pattern feature is Y and N, i.e. suppressed and not suppressed).
How can I achieve this? I tried various filters, but I can't figure out how to filter by this suppressed state.
Thanks.
@MK_8566483 wrote:
See attached.
I added following line to all your filter definitions
&fam.inst.name == *VYKRES
See drawing in attached data set.
I also added table containing 2D repeat region.
Don't know if this will work in your case, but in our BOM table, we have a filter to exclude components based on a part level parameter:
&asm.mbr.ORDER_CODE != ZZ
In this case, the parameter is ORDER_CODE. If the component has a value of ZZ, it is excluded from the table.
How can I achieve this? I tried various filters, but I can't figure out how to filter by this suppressed state.Thanks.
please upload your data.
@MK_8566483 wrote:
See attached.
Thank you, Martin
Marek
