Just wondering if anybody has faced this issue. I am trying to drill a through hole on a cylinder from side. It is a standard hole. I would like to put counter sink on both side. Now it just fails every time when I pick the "exit countersink" option. The enter side counter sink is fine.
Anybody knows how to make this work?
"One or both the hole entry and exit surface not planar.
Feature regeneration failed." --Message Log
I simple add it as a revolve after the fact. A lot of my designs have irregular surfaces on one or both sides.
I did the same thing so far.
But the headache is that the note of the hole has to be modified manually every single time.
