I'm trying to write VB code which will fetch BOM (bill of material) from ProE and export in to Excel
I've started with the following:
Dim model As pfcls.IpfcModel
Dim export_instructions As pfcls.IpfcBOMExportInstructions
export_instructions = New CCpfcBOMExportInstructions
I would appreciate any help on this. Where to start, what to read, etc...
Thanks in advance!
Simplified Logic offers a tool that will create BOM in MS Excel based on a Pro E assembly.
Hello
I created a format(.frm) with a table to creat my own BOM
this table gets the parameters from the parts, and creat a BOM from the assembly and simplify rep e chose.
then just select the entire table, and chose save table as .CSV
Then you can import the .CSV file to Excel
I assume you have solved this a long time ago. But if some other poor guy is finding this ancient post.
With the following .NET-Code you can get the BOM as txt-File
| // Create export-Instructions for BOM | |
| CCpfcBOMExportInstructions bomExportCreate = new CCpfcBOMExportInstructions(); | |
| IpfcBOMExportInstructions exportInstr = bomExportCreate.Create(); | |
| IpfcExportInstructions temp = (IpfcExportInstructions)exportInstr; |
| //export to file | |
| this.model.Export(fileName, temp); |
Best Regards,
Benjamin
