Hi All,
I am using ERP Connector to publish only Part data.
I want to include some IBA's of the Parts in the ESIReponse XML that gets generated.
I did the following:
1. Modified the ESIPart.map to include the IBA attributes
2. Changed the task xml used for "Query Part Task" to query the IBA's in addition to normal attributes.
But still I don't get the IBA's in ESIResponse XML.
Do I need to change GetPart.xml also ? How can I change it ?
Sameer
I guess I found the solution for the problem.
Need to edit the Example1.xsd in examples directory
for the IBA Attributes so that they get exported successfully.
Still, one minor issue: For Numberic attributes values are exported 2 times, once with correct value
and the other time with some binary value. No idea how to prevent this.
Tried option like maxOccurs = "1" in one of the xml file but no luck.
Any idea on this would be helpful to make solution clean.
Sameer
