Export SolidWorks to Creo
prebelo
Hello.
I have some files in SolidWorks extension which I want to import with Creo.
When I save PRT in solidworks, I open the file the Creo, and it doesn't ask me for any template and the accuracy is auto-set to 0.0012. With this option the solid is closed but I can't copy and paste all the surfaces to create a quilt.
When I export STEP in solidworks the solid has many opened surfaces.
What is the best way to do this??
Thanks in advance
prebelo
(To:prebelo)
Sir,
When I import the .sldprt file, shoud I use external accuracy?
Normally I use a template to import, and I pick the internal accuracy and closed volume option. Shoud I do this?
Should I export in solidworks on a different extension?
prebelo
(To:prebelo)
Any help?
prebelo
(To:prebelo)
I can't upload. Customer said to me.
But this happens to me with several files.
What is the best way to save and load the drawing in SolidWorks to Creo?
StephenW
(To:prebelo)
We sometimes have issues with step files. Have you tried IGES or parasolids (.x_t), surfaces or solid models.
have also sometimes had better luck when I export a surface model (not solid) then import and solidify. Occasionally it helps.
