Hi it is possible hightlights component in a drawing
bragini
11-Garnet
Hi it is possible hightlights component in an assembly  drawing when i select a baloon or a row in a repeat region table?. By default it's not possible
Someone know a work around to do it
Thanks a lot
Fabio
dschenken
(To:bragini)
Not that I've noticed through Creo 2.x
Why do you want to?
Hi Fabio,
If you select the row from the repeat region table, the BOM balloon, if shown, will highlight.  But the component does not.
Amit
