Export bom list to excel
kskatun
I would like to make a mapkey that export the BOM list from an assembly to excel.
typically this is the chain
  1. activate the assembly in the model tree
  2. right click ->view server properties
  3. activate structure tab
  4. Multilevel report
  5. actions ->export list to xlsx
However i would like to automate this process, by saving the list to a given location and start a batch file which den dumps the bom list into my database.
Is this possible?
My ideas:
  1. was to make a trail file and play this off,
  2. another idea was to read the html url "proep://local_proesession?oid=00134755.ASM&item=ASSEMBLY&id=0&action=info&action_mode=bom" but this only works inside the creo browser
  3. make a script that runs on windchill
  4. use some software (hotkeys) that simulate your mouse and keyboard clicks
Is it somehow also possible to get out which assembly that particular part belongs to?
3 REPLIES 3
dschenken
(To:kskatun)
I set the model tree to show only components and then expand all . Then save the tree. The result is space-character indented text file and can be parsed pretty easily for structure. Groups and patterns make for a small twist, but accounting for those is easy enough once the realization they need treatment is clear.
Basically, every time the indent increases, unless a group or pattern, the level increases and all those parts are in that assembly. If the level decreases then that's the end of an assembly, If it's a group or pattern, then if the level decreases by one or more, that's the end of the group or pattern. Keep the current assembly on a stack and pop the correct number off whenever the indent decreases.
BenLoosli
(To:kskatun)
Are you using Windchill or some other PDM system that would have your structure?
This is a OOTB function for Windchill from either the assembly file or the WTpart.
