Export of Combined States
pwilliams-3
All,
I am trying to export the combined states that are defined in my WF 4.0 model. In the recipe file I have all of 3 of the annotations checked as well as the Output Author States. However, in PV I'm not seeing where to access these states. Does anyone have any thoughts? Thanks.
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
2 REPLIES 2
Hello Patrick -
what is the version of PV you are using? if that is PV 9.1 - you should see them under the viewables tree which can be located on the left hand side of the application. Default you see structure tree and you need to switch to Viewable tree to get access for ProE defined view states.
Ramesh
Istill havethe same problem that Patrick describes.
I cannot view the "combined states" of an assembly in ProductView 9.1or even Creo View 1.0. I am using Wildfire 5 (M110) and Creo 1.0 M020.
I am using *.pvz format to export a model.
Are there any config options or some license restrictions on Creo View. I have the lite version - not professional or MCAD (I think that's the new name...).
Any ideas? Thanks in advance.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
