Is there an option to export the exploded views from a model to a 3D PDF?
I just exported an exploded assembly from Creo 7 using 3D pdf file format. it appears to work fine. Make sure you have saved the Creo explode state before exporting.
Could you point me to where in the Adobe interface to access the exploded view?
Thanks!
*Edit Nevermind - I see you have to export the model in the Exploded state. No option within Adobe to turn on or off exploded views. (I think)
Saved views in Creo can be exported to PDF, but explode states are not supported as far as I know. In my test I exploded the Creo assembly and then exported the model.
